Card test lỗi TL631 PRO cho PC và Laptop: Hướng dẫn sử dụng và bảng tra mã lỗi
Card test lỗi TL631 PRO - Hướng dẫn sử dụng (tiếng Trung) và Bảng tra mã lỗi (tiếng Anh) trong file đính kèm
TL631 PRO full view function diagram
01. LPC1 shared high-speed channel = connect the motherboard 2.0 small pin LPC
interface. 2.0 module
(module expansion LPC3 interface can be connected to the notebook MINI PCIE
conversion card. A-DEBUG conversion card. ASUS notebook DEBUG-CON, EC-DEBUG).
02. PCI high-speed channel = supports all PCI slots.
03. LPC2 shared high-speed channel = connect to the motherboard 2.54 large pin LPC
interface. ASUS COM-DEBUG. ASRock UART1, MSI JDP, Supermicro SPI.
04. PCIE X1 high-speed channel = support Gigabyte without PCI motherboard
(other brands do not support)
05. 3VSB power indicator light. Check whether the power supply is normal.
06. RST reset indicator, to check whether the motherboard reset is normal
(only when PCI. PCIE is inserted).
07. CPU indicator, to detect whether the CPU module is normal.
08. DRAM memory indicator, to detect whether the memory module is normal.
09. VGA graphics indicator light, to detect whether the graphics card module is normal.
10. PCH south bridge indicator light, to detect whether the south bridge module is normal.
11. DP decimal point, CLK signal display.
12. DP decimal point, FRAME frame signal display.
13. Banghoro gold cord or keychain.
TL631 Pro interface description:
  • LPC1 high-speed shared channel, connect to the motherboard 2.0 small pin header LPC interface, 2.0 module (module expansion LPC3 interface which can be connected to notebook MINI PCIE conversion card, A-DEBUG conversion card, notebook DEBUG-CON, EC-DEBUG)
  • PCI high-speed channel, support all PCI slots.
  • LPC2 shared high-speed channel, connect to the motherboard 2.54 large pin LPC interface, COM-DEBUG, ASRock UART1, MSI JDP, Supermicro SPl.
  • PCIE X1 high-speed channel, support Gigabyte no PCI motherboard (other brands do not support).
  • 3VSB power indicator to detect whether the power is normal.
  • RST reset indicator to detect whether the motherboard reset is normal (only when PCI or PCIE is inserted)
  • CPU indicator light to detect whether the CPU module is normal.
  • DRAM memory indicator to detect whether the memory module is normal.
  • VGA graphics indicator light to detect whether the graphics card module is normal.
  • PCH indicator light to detect whether the southbridge module is normal.
  • CLK signal display, FRAME frame signal display.
Gemini drive module
Newly created BGA type driver module. Concealed parts design to prevent dropouts.
The TL631 PRO card does not see any resistance or capacitance, it looks beautiful and
generous, and it is more free to use.
Integrated patch digital tube
Self-developed binding digital tube,
brand LED core, bright and comfortable, thin and scientific sense.
The appearance difference between
TL611 PRO and TL631 PRO
The appearance of the fifth generation TL631 PRO has no layout resistors and capacitors
Test sample
  • TL631 PRO说明书.doc
  • TL631 PRO转换卡说明书.doc
  • UEFI-BIOS DEBUG - Edit.doc
